Lemons Mk2 Build - Page 116
Page 116 of 120 FirstFirst ... 1666106114115116117118 ... LastLast
Results 1,151 to 1,160 of 1200
  1. #1151
    CelicaSupra.com Member revvhappy's Avatar
    Jun 2013
    Georgia
    1,218
    If I had to remember all these wires I'd be in serious trouble! The labels are a godsend. I even took the time to draw my own schematics of the entire system.
  3. #1152
    Jun 2013
    Georgia
    1,218
    First start: https://www.facebook.com/hongnorrth/...3351553724594/
    The oil pan has a slight drip, probably from the flange warping a bit during welding.
    Next stop - a dyno for tuning.
  4. #1153
    CelicaSupra.com Member brett85p's Avatar
    May 2015
    St Louis MO.
    103
    I dig this engine swap!
    1978 Toylet Celica LeMons Racecar
    2.2 Ecotec Engine, Colorado Trans, Mk1 Supra Rearend
  6. #1154
    10,205
    Nice, congrats! Hoping there is a big update coming!
  7. #1155
    10,205
    Technically your car is just a Celica now, with a Supra nose swap
  8. #1156
    Jun 2013
    Georgia
    1,218
    The extended wheelbase helps stability while racing. I often wonder if the K24 engine placement in a Celica would be better than the Supra.
    I had elbow surgery last Tuesday to get a very old injury repaired. I can't do anything strenuous with the arm for at least 6 weeks. Before the surgery I was able to remove the engine and get the oil pan sealed, then install everything again. The final wiring is complete but not tidied up until I'm sure that the engine runs on the dyno. My best guess is Mid-October for tuning.
  9. #1157
    Jun 2015
    New Jersey
    96
    Happy to see you're back at it! Looking good!
  10. #1158
    10,205
    The Supra with that engine would net better overall weight balance, stability and probably aerodynamics. But a Celica, especially a GT with a solid rear, would be substantially lighter, which would probably trump the benefits the Supra has.
    My buddy just finished his Beams swap into his 85 Celica GT with mk1 Supra swap already done. That thing is so light, its much more like a slightly larger, angrier ae86 then a Celica Supra.
  11. #1159
    Jun 2013
    Georgia
    1,218
    Quote Originally Posted by SupraFiend View Post
    I've seriously started to look for a Celica GTS (already has the 7.5 Diff) or Supra shell. My chassis has taken a lot of abuse and modification through 15000 race miles and a few crashes. I'd love to have a clean slate to put everything I've learned into a better package.
    There is a rumor that Champcar might increase the swap budget upward $1000. The one thing that's holding up most progress on this project is the OE TSX intake manifold - there are too many components trying to fit into the same space along the firewall that it's not safe (there is also the hole in the firewall to clear the throttle body). I finally gave in and ordered the new KMiata intake for RWD cars which positions the throttle body toward the front of the car. This will free up plenty of space for the fuel line, coolant line, throttle cable, and more. It will also allow me to weld the firewall closed and build a more efficient CAI. I hope that the rumor becomes reality or I'll be way over the rule budget.
  12. #1160
    10,205
    FYI, only the 85 Celica GTS has the 7.5. Even the GT of that year has the 6.7 solid rear, all other years of GTS have a 6.7 IRS pumpkin, mated to a bespoke subframe as well. Of course swaping the entire IRS from any Supra is simple. Finding a mk1 Supra rear axel is not, and brake part supply for it is getting pretty bad.
There are currently 11 users browsing this thread. (1 members and 10 guests)
  1. supraz
