My R154 writeup with pics - Page 16
Page 16 of 16 FirstFirst ... 6141516
Results 151 to 157 of 157
  1. #151
    CelicaSupra.com Member ABQMK2's Avatar
    Mar 2004
    DFW(Keller) TX
    3,014
    Clutch disc will work...pressure plate won't.
    I'm running raptor racing's feramic W58 clutch disc with my R154, I'm just using a different PP.
    Also the front half of a Mk3 auto transmission drive shaft attached to your Mk2 W58 rear section driveshaft will work...make sure you also use a Mk2 auto transmission crossmember.
    '83 P-Type 2JZ "Wicked Felina"
    668whp/[email protected] on E85
    483whp/[email protected] on E85
    Hidden Content
  3. #152
    Jan 2005
    Atlanta
    612
    Couple tips as I am in the middle of my R154 swap.
    1. Do the test fits before putting the pilot bearing or flywheel on. Much easier to do a couple test fits when you do not have to get the transmission over the flywheel and perfectly lined up on the pilot bearing.
    2. I tried the air hammer, claw hammer, 10 lbs slide hammer, and even some mild blow torch. The tunnel did not budge. I decided to do a twist on William's idea. I went to Walmart and bought a 2 ton bottle jack for $15. I installed the manual transmission cross member. I then wedged the jack in and pressed it up against all the areas I marked on the first test fit. I pushed the tunnel out as far as the jack allowed. It rebounded back a decent bit after I released it. Did this several times on several different points of each side where I wanted to expand it. Next test fit was perfect. Total time was 30 minutes.
    Hope this helps others.
    -John
    82 Supra: L Type Terra Cotta Hardtop stock 7MGTE MegaSquirt 2 (set up for racing)
    82 Supra: P Type Black built 7MGTE MS3 400HP (cruiser)
    95 BMW 318TI: Daily Driver
  4. #153
    CelicaSupra.com Member CLToy's Avatar
    Oct 2005
    Charleston, WV
    2,159
    Excellent tips. Thanks.
  6. #154
    Jul 2007
    Norwalk, IA
    1,059
    Quote Originally Posted by johnb7 View Post
    That's exactly what I did! Worked like a charm and required no heat, moving of carpet, etc... I can't say it took 30 minutes though :/, definitely took me a couple hours. But I put the car as high as I could in the air, put the trans on a trans jack and test fitted that way... then cut the section out for the shifter hole.
    MegaSquirted 62mm 7m @ 20psi on 91 octane
    410whp/411ftlbs
    Hidden Content
    Hidden Content
  7. #155
    CelicaSupra.com Member TRD 83 SUPRA XX's Avatar
    Jul 2003
    Fontana Cali.
    8,413
    LOL this thing is giving me a headache! Almost done now tho.
    Hidden Content
    Get your MK2 Supra Cooling Plates here
    Hidden Content
  8. #156
    Jul 2003
    Fontana Cali.
    8,413
    FUCK ME!!!! Took forever on my Supra. Trans hall did not want to budge! BUT I AM NOW A R-154 MK2!!!
    Anyway I highly recommend using a cylnder jack like the guys have been talking as of late. IT WORKS!!! Dont get discouraged because it bounces back into shape. Keep at it and push in the high points. I dont have pics to help but it WILL WORK.
    My work time for me was 8+ HRS!!!
    Thats me for not having all the right tools.
    Hidden Content
    Hidden Content
  9. #157
    Nice work.
There are currently 4 users browsing this thread. (0 members and 4 guests)
