wow, sure would like to see the car when all is done !
My guess is that as long as you get wheels that are hubcentric (60.1mm in centerbore) watch your lugnuts for correct torque (I use 80 ft/lbs) and check your wheel bearing often, should be ok. Your bearings will wear quicker due to the negative offset you need to run, but heck, the car is lighter than stock too. You didn't mention what diameter wheels, that would be interesting to figure out overall gearing. I can't imagine using larger than a 17" wheel unless you are also changing rear end ratios.
What type of tires would you run ? I think Hoosiers in a 315/35-17 and maybe 285/40-17 would be about 25.6" overall diameter, when stock is close to 24.5". With the power you plan to develop, maybe the bigger overall diameter tires would be good. I say go for it ! It's racing !
Don L.
'84 Supra
Don L.
'84 Supra
