1 - 6 of 6 Posts
The Mk2 L-type model did - the P-type did not.
I don't know the exact number of L-types that did come with them, but they aren't as wide as the alloy wheels on the P-type, nor do they look like the wheels on the P-type.
Hope this helps.
The '82-84 L-types came with a 14x5.5 wheel that was a different style than the p-type wheel. The '85 l-type came with a 15x6 variant of the P-type wheel. They look pretty much the same, but have a higher offset, +20 if I remember right. THey look very nice on an L-type with 225/50/15 tires.
Chad,
Yep, the 15x6 wheels have a +20mm offset.
kllntyme: These wheels will pretty much fit on to any year L-Type, but they won't fit correctly onto any year P-Type. The +20mm offset will make the wheel sit inside the wheel well too far & the flares will stick out. The L-Type's won't have this problem.
Also the 15x6 wheels make for a great wheel upgrade for MKI's. Damon Saul has done this to his Black 81.
I saw in a picture post that some people were interested in this 15x6 OEM style wheel, but don't know where to get them. When I was deciding to upsize my wheels I came across the following site. They are a Wheel Refinishing company in the USA.
Go to the following web-site:
http://www.aaarims.com/cgi-bin/Web_store/web_store.cgi
It asks you to enter a Product ID #. Enter 692131F and Press "Submit Search".
The company is in Holland, MI.
The wheels definitely are flatter in profile than the 14x7 on the P type. I would imagine that a 1/2" spacer would space the wheel out better, but then you've got the issues of longer wheel studs and hub-centric centering of the wheel.
They list for US$155 per wheel less centre caps.
Worth a look for those who like the OEM look but want slightly larger diameter tires.
Dale
1 - 6 of 6 Posts
