Using an R154 I'm guessing?So jz is in
For the driveshaft i have a mk3 auto front one but the hole that support the bearing is not the same
If I remember right it's pressed on to the shaft. You'll need a puller tool to get it off.yes 154 ,not sure the W58 have lasst long behind the gte...
how did you unbolt the carrier bearing?
