1 - 16 of 16 Posts
Addict
SOLD SOLD SOLD
Hello ladies and gentlemen. This 1985 Toyota Celica supra P type is up for trade and sale.
Serious buyers with PM can get Pictures, and Carfax.
Garage kept.
170,000 miles roughly on the chassis.
Known issues current:
PS line to pump needs new hose clamp,
used diff could use seals
Idle tune is too lean currently for warmer temps
small paint issues on front bumper (near DS headlight) and rear bumper(left) can take pictures.
left rear taillight has a chip and crack, but visually looks ok.
New Dr Tweak engine wiring harness
custom motor mounts
Stock cams
Engine managment system
AEM v2
Racepak display
AEM Failsafe
LQ9 Ignition
Fuel System
Walbro 400 fuel pump
Fuel pressure regulator summit
Aftermarket rail
-6 return line
ID 1050cc fuel injectors
Blitz Intercooler
well built IC pipes 3"
Polished MK3 radiator
Turbo-BWS366 Billet .96 AR housing 3" Vband, Turbo blanket
ebay 2JZGTE manifold
TIAL 44mm WG 18psi spring
Custom DP 3" with WG dump pipe to magna flow muffler
Tial MVR 44mm BOV
Suspension
Camber plate
Whiteline sway bars front and rear
Super pro poly bushing throughout
Wilwood BBK Front and Rear
Simmons 17" FR17
-4 x 114.3 bolt pattern
-60.1 mm center bore
-Fronts - 17 x 8 +10 offset 245/40/17
-Rears - 17 x 9.5 +0 offset 275/40/17
4.30 stock rearend
Transmission R154
New OEM seals
Short shifter
New OEM seals and gaskets.
Clarion DVD/bluetooth head unit
Tons of Supporting Sensors and parts not listed. You can PM for full list if you want.
All stock amenities work for the most part, haven't check rear wiper, AC not complete.
Dyno car made 467RWHP and 427RWTQ @18psi
Fuel system setup to run E85 with sensor and correct lines, around 30Psi
Car runs and drives. It needs a tune(idle enrichment) , Motor has A/C compressor but no A/c Setup. Heat works. Many parts are replaced/new.
comes with a new power steering rack/ Muffler/ tons of spare parts worth $1,000 roughly
I will answer any questions and take any photos you have.
Car was worked on by Majestic Motorsports in NC and
Niced up Performance and myself.
OLD Chassis Build thread:
https://www.celicasupra.com/forums/showthread.php?68879-New-Well-everything!!!
Very nice! GLWS
I just realized, this setup was my dream car when I was in the supra game (85 with a 2jz/r154). Man I wish I had the money to get this. I hope it lands in good hands.
Addict
Discussion Starter #5
Thanks, had a serious buyer today drop buy and look at the car. said he will make a cash offer soon. He is in the process of restoring a 85 torino to original. owns 19 cars and seems like a good owner :)
You can always start your Montana llc...
Addict
Discussion Starter #13
Car is sold to CrazyRussky in WA. Seems like he will be a good new owner by finished all the odds and ends the car needs. Glad she’s in a good home. Sold on Bring a trailer
1 - 16 of 16 Posts
