1 - 20 of 24 Posts
So I have replaced the lower value cover gaskets as the were leaking oil. Replaced intake manifold gaskets, had fuel injectors tested and all is good.. New distributor cap, rotor. Lined up the timing to top dead center. Checked fuel pump relay and all is good. When I start the car I don't hear the fuel pump which worked before all work performed. So looking at the video it seems like the car is starving for fuel. Fuel line into the intake manifold has to brass washers and I place one above and one below the fuel line near intake manifold. The bolt has a hole for fuel to flow through but I did see any info on alinement or proper hold placement. Check out the video link and help me get this car started. Thank you. New video by Lawrence Bagnell
Check EFI fuse under the hood...
Sounds like the ignition timing is way way off.
Anyone have info on setting cam to BTDC. I pulled headcovers and lined cams to holds open. Inserting Distributor lined up to dot and line and rotor cap turns between cylinder 1 and 4. When we pulled the cam gears we put marks on TDC but replacing them and following instructions aligning the three pin holes to marks on cam rear cover our makers are off 180 degrees. I don't see how pulling cam gears sprocket then following instructions would cause this problem. PS I cleaned and replaced gaskets in intake manifold as well. THANK YOU. SO starting from scratch DOES anyone have instructions?
I will also add that we pulled intake manifold and replace gaskets and cleaned. Pulled injectors and had them serviced. Added new injector electrical clips and kept original pins in wire harness. Meaning we popped the pins out of the old and put them into new clips instead of cutting wires.
Reactions: dcbagnell16
Maybe distributor is 180 degrees off??
Turn the crank to "0" (TDC) and make sure that both marks on the cam gears point at the notches on the cover. Then remove the distributor cap and make sure the rotor is pointed at the #1 terminal. After all that use a timing light to see that the light is going off around 10 BTDC.
Spin engine over 1 full revolution. Cams will spin 1/2 revolution and be perfect.
Discussion Starter · #14 ·
So timing is TDC. It seems fuel is the problem. Going to remove intake manifold again and check fuel pressure first. Then injector clips and change fuel filter.
Question for Supra peeps.
When you turn the key to the on position DO YOU HEAR the Fuel pump turn on???????
...When you turn the key to the on position DO YOU HEAR the Fuel pump turn on???????
No, on the 5M the only time the fuel pump works is when the AFM flap is open or the check connector is shorted.
Furl pump also works when cranking the engine over but shorting the yellow connector will tart the pump up. The connector is near the AFM. But the pump worked fine before, so like Silver said, probable bad timing.
So update is this. I tested the cold start injector with jumper wires to 12volt battery. Spit very little to nothing. Order new one from Japan.
Also test resistance to fuel injectors injectors. All consistent reading. Checked Fuel injector clips with key on and battery connected. 1,3,5 no reading and 2,4,6 same voltage. Figured ECM controlling voltage that is why I'm not getting readings on 1,3,5.
Replace fuel filter. done. Waiting for cold start injector then reinstall intake manifold.
QUESTION. There is a grounding wire that runs from injector wiring harness. Where does it connect to confirm I'm in the correct place?
All injectors should read the same, as they are all feed by the dual resistor, and the ECU does provide the ground to fire them up. See here: MK2 TSRM On-Line
In that area of the engine harness, there is at least two (2) ground rings. They attaches to a bolt (between cyl 2&3) at the jonction of the runners and intake chamber.. They need to be connected, they are ECU power ground, and sheilds.
Discussion Starter · #20 ·
Update Oct 16 2021. We got it started yeppie. Here is the issue now. If we advance the timing then we cannot see the timing mark on crankshaft as it goes above 15, but car runs great. If we stick to the manual on specs for the 5MGE 85 Supra it runs rough. Below is the update for and suggestions. Thank you in advance:
Oct 16, 2021 video: New video by Lawrence Bagnell
Pulled timing belt again and lined all marks up by pulling #1 spark plug and raising to highest point, pull valve cover and turned cams to open marks and inserted bolt to lock in place, pulled timing belt and realigned, had crankshaft to zero. Car starts and runs rough. Updated video
It starts. Set timing to 10 degrees and idling rough. Tried to advance distributor one tooth, the two teeth, then back one tooth, two teeth and now to marks as described to set distributor above. It only runs with settings now as stated above.
What could be the problem?
Timing was is set
EGR valve all good
Injectors - cleaned and reinstalled
Compression good
Fuse - All good
Relay - check relays and they are in good working order
Fuel injector clips replaced
The car in order to be inspected needed a catalytic converter installed. All worked well with the car for about a year and then the misfire started to occur and I noted an exhaust leak between the pipe connecting the catalytic converter and the exhaust manifold pipe. Going to sh#* can the catalytic converter and run straight pipe soon.
1 - 20 of 24 Posts
