Stock ECM and IAC system? Valve could be stuck for sure. A vac leak would cause high idle. Id remove it and clean it out etc.
On the swap harness where does the IAC get its 12V power from? You can confirm the middle 2 pins of the 6 pin connector should get 12V when the car is keyed on.
