You planning on selling those nice MKIV Supra 2JZ machined cams???I have two pair of 2j stock cams that I milled down at my shop that I don't need 1 set is aristo 2j cams that are slightly small than the other set which is mrk4 cams. I tryied them all to find out what the difference would be(dyno tune with AEM ) the aristo were 20 hp gain at same boost and the mrk4 were almost 30hp gain and they both came in sooner and pulled harder in the upper rpms. I then changed to the BCrowler 268 which lost 600 to 800rpms spool up but gained double on the mid and top end almost 60hp and I can rev to almost 9000rpms now. They make good power from 4500 to 8500. I was making 340 hp @14psi w/1J cams to now 440hp w/268 cams with the same boost.
Absolutely! I'm still running the 2J cams and I love them.Thanks for the info.
So if I just running the stock 1jz ecu now, will it be able for the engine to run smooth and still get the power? By the way I'm trying to go single turbo now.
Thanks
I was really hoping someone did this with the same car and setup . I have Aristo cams and i've been on the fence about putting them in. Any dyno results to compare ? Nice numbers btw :thumbsup:I have two pair of 2j stock cams that I milled down at my shop that I don't need 1 set is aristo 2j cams that are slightly small than the other set which is mrk4 cams. I tryied them all to find out what the difference would be(dyno tune with AEM ) the aristo were 20 hp gain at same boost and the mrk4 were almost 30hp gain and they both came in sooner and pulled harder in the upper rpms. I then changed to the BCrowler 268 which lost 600 to 800rpms spool up but gained double on the mid and top end almost 60hp and I can rev to almost 9000rpms now. They make good power from 4500 to 8500. I was making 340 hp @14psi w/1J cams to now 440hp w/268 cams with the same boost.
Same here, o wait?!?Absolutely! I'm still running the 2J cams and I love them.
Thanks to you guys its hard to find a set of good condition USDM TT cams, lol.
Hold the phone...Dem's mine! :laugh:I have a set...Do you want them?
lol??¿¿?Hi
Acai Berry will help you change your life.
This all natuaral wieght loss soltion leads to effective weightloss.
Get your free trial today.
Acai
[email protected]#%J2
Another one???Ban!!!
Will these work on a 1jz Gae ofc I'll need to upgrade other things.im just looking for some upgraded cams thatll fit the 1jz geStop paddling around in the shallow end and get yourselves a set of HKS 272's. You'll love it.![]()
