cant just wind the idle up to 1450? or is that all electronic these days... hmm.
thx for the reply.cant just wind the idle up to 1450? or is that all electronic these days... hmm.
Is it possible to set the IACV so that it runs on around 1600 RPm without load and when the load is applied it should drop around 125-150 rpm under load.Remove throttle body and install a plate, or weld the TB shut. Then drill a small hole into the plate/throttle plate, check its RPM. Go larger and larger with the hole until you reach your RPM point. Then the IAC valve should be able to compensate when there is more load applied to the engine.
2JZ's have an idle up vac control for the power steering, you might be able to adapt something to that using a solenoid on the vac line to control the rise rate.
Just a few ideas.
Just a few ideas.
