As of tonight my 2JZGE conversion is complete! :rockon:
It going into be registered over the next couple of days! I can't wait to have a proper drive and actually wind it out to 6000rpm
Once the tacho was wired up i established i was probably only going to around 3500-4000rpm
The conversion keeps the W58, uses a JZA80 W58 bellhousing and custom engine mounts that bolt onto the 5M mounts.
Power steering feels much better than stock!
The exhaust utilises the factory manifolds with 2 inch secondaries joining into a 2.5in collector and 3in hi flow cat...with some such massive ricey muffler at the back, it is well loud! :twisted:
Only other mod is an extended intake with pod filter to get it into the corner of the bay out of the heat.
Here are some pictures, but the battery died in the camera and ive been too busy getting everything back together! (You will need to copy and paste them into a new window as they dont work as links)
www.geocities.com/ifli4u/2jzmounts.jpg
www.geocities.com/ifli4u/jza61.jpg
www.geocities.com/ifli4u/jza61rear.jpg
www.geocities.com/ifli4u/underdashwire.jpg
Oh and they are 265's on the back....on stock rims 8)
