I have decided to go a different route so my 2jzge swap is for sale.
Transmission: is300 w55 155k mileage, converted to fit into the mkii
  • Speedo gear converted for 3.90 diff
  • Xcessive manufacturing poly trans mount
  • mkii manual cross member
  • shifter
  • bellhousing bolts
  • dual mass flywheel with bolts
  • clutch slave cylinder
Engine: is300 2jzge 155k mileage
  • is300 manual ecu, immobilizer key, and wiring harness
  • is300 starter and harness
  • is300 ac compressor with lines
  • power steering pump and lines
  • throttle cable
  • maf
  • appears to have new timing belt and tensioner
This is almost everything needed to swap a 2jzge into the supra.
Price: $3,000
Located in Huntsville, AL local pickup is preferred.
