1 - 9 of 9 Posts
Discussion Starter #3
On one head I had rebuilt a two angle valve angle was done, now a 3 angle will give better flow possibly, so to be specific, is it beneficial?
It should be. Just about anything you can do to improve the airflow will help, and having additional angles above and below the seat helps the airflow.
How much? I've never seen any figures, but it's probably in the "A Few Horsepower" category.
I just looked in the shop manual, and the OEM specs are for a 45* seat, with a 60* undercut, and a 30* blend cut, so if you get a true "Factory Spec" valve job, you'll be getting a "three angle" valve job.
Whistles
There may not be that much gain you will ever notice. This question has been discussed on other Supra sites, albeit the focus were GTE variants.
When I spoke with Dave at Headgames about everything possible in options, we didn't even talk about it. It may be most helpful on NA or nitrous applications, I am not sure.
Discussion Starter #7
Well I guess my valves are getting a 3 angle, thanks for the research!
Unless you damaged something it's unlikely the valves need to be reground. Usually just relapsing things is significant.
Discussion Starter #9
I performed a leak down test and found some valves leaking. A trick I found was to spray a liquid soap in the valve chamber and when leaking, well you'll see the bubbles
1 - 9 of 9 Posts
