1 - 7 of 7 Posts
what do i have to do to the KYB GR-2 V2 so they work on a stock 85 supra i know a shim on the fronts but your site also says rear need modification i e-mailed twice and all i got was "GR-2 is direct fit" not what i asked.
You need some washers to make up the difference in length. These struts are slightly shorter than stock.
I believe it was 5/8" washers from home depot. You will need ~10 of them.
Aren't the GR-2's a direct fit, as in you remove the old ones, put the new ones in, and drive the car?
And for rears, it should be the lower bushing needs swapped out.
maybe they are gr-2's for the mr2? would be a little stiffer then the gr-2's for the supra.
Ahhh, that explains it then.
1 - 7 of 7 Posts
