1 - 20 of 24 Posts
scott dont use the helper springs!
then the GC will sit even lower
what struts are you going to run?
Dunno what you're talking about. Those definitely aren't ground controls. However, I wouldn't use the helper either. It's not a flat coiled spring and is going to bind up weirdly at the top.
yeah I havent decided if I was going to or not. I was leaning towards the not.
I just hope that when I drop it I dont have any issues with my lower IC pipe as it is already just as low as the bottom of my cressida lip...so I will probably install these and leave it at about stock ride height until I can remake my lower IC pipe....
as for struts I will be running some new gy2's....I know they arent great but they will be much better than the stock almost 200k struts I have.
lol they look very similar to my GC's
but yeah keep that helper spring out O did you get RCA's????? your going to want some
not currently....and probably wont pic them up for a bit.
but I wont be able to really lower the car much anyways (cause of the ic pipes) for a bit.
When I lower the car I will start looking to pick some up.
scott RCA's do not lower the car!
they make the front end level!
how low does the car have to be for you to need RCA's?
NOOOO RCA's do not lower the car
you need them to level the underside out
i already know they dont lower the suspension i was wondering at what point do you need them.
*sorry for the thread jack*
lol sorry scott that wasant directed at you lol
that was directed at the guy threadjacking
Rusty without RCA's wont the front slide and dig in on corners?
RCAs keep the lower control arm in the OE position to prevent bump steer.
1 - 20 of 24 Posts
