I installed a junkyard 5M-GE into my Cressida. Finally I got rid of all the ECU codes. The car starts after a little hesitation, hasn't stalled on me once. But the engine vibrates and it lacks power under load. I did a compression test:
157-149-150-150-151-162
Checked the plug wires, new cap and rotor, swapped injectors with a set that are known to be working. Still shakes with not much power. The timing is also set properly.
Here are my questions:
1. I pull the spark plug wires 1, 4 and 6 off the plugs with the engine running without any change in engine idle or vibration. Removing 2, 3 and 5 drop the idle. Any ideas why those plugs make no difference? I checked the actual plugs, and they don't look too bad.
2. My Air/Fuel ratio gauge is showing a stoich reading from the second I start the car and doesn't change much after it's warmed up. I don't recall it showing any ratio until the O2 sensor was warmed up with the last engine, but that was in the winter. What's normal readings for the air/fuel ratio at startup and idle?
3. I installed a Fidanza aluminum flywheel, should that have an effect on engine vibration?
4. Could the TPS sensor make the engine vibrate and lack power? I tried to adjust it so that it would meet all variables in the TSRM, but it's slightly out of range of some of them.
Thanks in advance,
Christian
Thanks in advance,
Christian
