Search the term "suicide hose" on this site and you might find your answer. Welcome!
so I take it the only way to get to that hose without pulling the engine is to take off the intake? at least with a semi-limited tool box. with the iscv and the throttle body, if there isnt any cracks or anything could there be anything wrong with them other than a gasket? sorry if I sound like an idiot. I'm used to old chevy'stheres a coolant hose that runs along the underside of the intake manifold. a real pita to get to with the motor in the car and the intake on. theres also the iscv and the throttle body as well on the the drivers side, which have coolant flowing through them.
well, if you have small hands, you can probably get to it without taking the intake manifold off. i know that i probably couldnt, so i replaced mine when i had the motor out of the car. the reason i mentioned the throttle body and iscv was to check those hoses for cracks or leaks first, since if they are leaking, they are alot easier to change then the suicide hose.so I take it the only way to get to that hose without pulling the engine is to take off the intake? at least with a semi-limited tool box. with the iscv and the throttle body, if there isnt any cracks or anything could there be anything wrong with them other than a gasket? sorry if I sound like an idiot. I'm used to old chevy's
a friend of mine is going to come help me out with it. I guess back in the day he had the same car with the same problem. supposedly its a defect and he knows what it is already. I'll keep you guy posted. thanks for the help.I dont think its shop worthy. For a lot less you could buy some strange tools and do it your self. Curled needle nose pliers helped on mine if I recall. I got a lot of funky tools, they come in handy for these cars. I would suggest finding your leak, or replacing the questionable hoses.
Look at the project and figure out what wacky tools would make it easier. Shop will likely pull off intake and charge ya an arm and a leg for it. It really isn't a quick task.
