1 - 20 of 21 Posts
I'm looking into the specs for the Crank Pulley of a 5m-ge with dimensions for the angle for all of the ribs and the Vs on the outer part, as well as the general size of the parts that constitute the pulley would anyone know where I could find this? Could be old forum posts or document, just looking for specific measurements
Thanks!
IF your using a late crank pulley then the alternator pulley is the same dimension width 25mm for the rib belt on the crank pulley...
OEM fitment to 27411-43050
Rectangle Font Parallel Slope Diagram
Reactions: supraz
EU Version, 1982, Red, 5M-GE, Black interior with purple seats.
Woah, do you have a diagram like this for a water pump pulley?
Lokasz, I do not...
I can try to do some research? For a '82 5MGE??
Does the pulley have ribs or V-belt??
IF this is the correct part # it is used in the following Toyota vehicles
Part 16173-43040 (PULLEY, FAN) was found on the following models:
MarketDate rangeModelFrames/OptionsFound in diagram
Europe08/1981-11/1985TOYOTA CELICAAA63,TA60,SA63,RA6*,MA6116-01: WATER PUMP
N. America08/1981-11/1985TOYOTA CELICARA6*,MA6116-01: WATER PUMP
Europe09/1980-03/1985TOYOTA CRESSIDATX62,RX6*,MX6*,LX6016-01: WATER PUMP
Europe08/1984-07/1988TOYOTA CRESSIDAYX70,RX7*,GX71,MX7*,LX7*16-01: WATER PUMP
Europe08/1988-07/1996TOYOTA CRESSIDAGX81,LX80,MX8*,RX8*16-01: WATER PUMP
N. America09/1980-06/1984TOYOTA CRESSIDAMX6*16-01: WATER PUMP
N. America08/1984-07/1988TOYOTA CRESSIDAMX7*16-01: WATER PUMP
Europe08/1983-07/1987TOYOTA CROWNYS120,MS12*,LS12016-01: WATER PUMP
Here you go!!
Font Line Auto part Line art Circle
Crankshaft pulley
13407-43020
Pulley, Crankshaft
[08.1983 - 12.1985] 5MGE..MA61
Ribs should be 25 mm wide like the alt pulley
Automotive tire Font Circle Auto part Automotive wheel system
I see, all I can se is the single crank pulley picture, where would I go to access more of them ?
Why don't you call Toyota in Japan and ask them to dig out there 5MGE crank pulley drawing from 40 years ago since that is who has it :LOL: All the belts dimensions are fairly standardized. Dig up a Gates engineering catalog for those. The rest you'll have to reverse engineer it with your calipers.
get an original and scan it with a 3D printer?
What are you wanting to do ? there are several companies that sell the standard SAE pulley grooving tool that will give you the form. Back in 2002 though before I knew this I made my own supercharger pulley for a tacoma I had with a more standard insert on a cnc lathe . If you have a pulley , a machine shop with a cmm can easily reverse engineer one , but don’t forget that there’s a torsion damper built in …. again all depends on your end goal
Sent from my iPhone using Tapatalk
Discussion Starter · #20 ·
I just need to find the specific sizes of the teeth of a 5mge harmonic balancer as well as the angles of those teeth
1 - 20 of 21 Posts
