1 - 2 of 2 Posts
I'm finally starting my engine(5mge) after being down for about a yr now due to the fact of sourcing parts and cash after spinning a bearing a an totalling the crank. But this is my big wen i pulled down the engine(84.5mge) i found 6m rods with hi comp pistons with 5m crank an 6m main bearings i guess so i guess that equation=83 5mge's HP correct me if i'm wrong. I only realized all that when i got an 83 5mge engine which i'm not going to use. But here's my prob i can't get my hand on 5mge main bearing can i use 6m main bearings. Need an ans asap Plz thanks
Later 5M, 6M, and 7M main/rod bearings are the same, it is the size that you need to make sure of.
1 - 2 of 2 Posts
