1 - 19 of 19 Posts
Sorry if this is a bad qestion, but why gtR? Looks fast though. Good luck with tuning.
Turbonetics T60-1
Tial 44 mm waste
Turbonetics Raptor blow-off
HKS Exhaust 76 -80 -85
MSD Coil and 6BTM (not well working yet)
Turbosmart e-boost2
AEM UEGO
MAF-EMULATOR2
Setrab oil cooler with Kinokuni thermostatic block
32GTR Intercooler
Titanium piping from FLANKER
Custom intake
and many-many more))
5M turbo is quite fast
and i like the way it is
I ran now only 6.5 psi, but this is on 9.2 CR
everything works quite ok, even on a stock ecu, have only some problems on enrichment with deceleration as i have blow off opened to atmosphere, but in a shortest time will hook ou MAP-based MAF emulator.
and on my turbo exhaust housing is 0.46 and it hits the boost on 4000 rpm. Have a little lack of power after 5500 - gate (44mm) is a bit to big for this low boost, and while it is opened turbo losts quite much of a boost.
anyway the efforts spent are worth
NOTE: the fuel system is fully stock - even walbro and AEM PFR sitting on a shelf..
and i experienced no knock condition or lean mixture
i really like your set up you should post some videos of the beast are the internals stock? and what compression do you have? stock headgasket?
Discussion Starter · #14 ·
head gasket is stock original 7MGTE with ARP studs.
Internals are stock 300 thousand miles)) except custom SS exhaust valves by Si-valves and exhaust LS1 Camaro valve springs
and also slightly ported channels and slightly polished
Fidanza flywheel and stock 7m Clutch
runs faster than na but still have some minor problems)
Cannot hook the BTm up - sometimes engine losts spark and doesnt start again for a while - really frustrating situation with absolutely new MDS (and i checked it with white wire as manual says - all is okay, maybe old 8910 HEI tach adapter doesnt fit as it should - i do not know)
It must be the fastest mk2 in russia. I think the are rare overthere..
Great work... Keep up posting pic.
Want to see the whole car.
that car is hot as fuck.
is your celica xx badge falling off?
that car is hot as fuck good job sir!
i just read war and peace russia ftw
oh you did notice.. the xx badge .. i just glued to the wrong place.. and stepped with my knee in the center of panel causing some cracking on it)
PS: i was not able to read that book copmpletely.. bored me after second book of four) - luck with that!
1 - 19 of 19 Posts
