1 - 1 of 1 Posts
I have a 6M crankshaft from a 7MGTE that has some damage on the front snout due to a wobbly harmonic balancer. The surface metal is fatigued and worn a bit especially around the key cut out. This got me wondering about machining the crank down to accommodate the harmonic balancer from the 5MGE. So, my question is whether or not the 6M crank can be machined down smaller to accept the 5MGE balancer. I currently do not have a 5MGE balancer to check the specs. Do you think the crank snout can be machined down to fit? I am working on a frankenmotor build.
David
1 - 1 of 1 Posts
