1 - 4 of 4 Posts
Not sure how to start this, so here it goes:
The turbo, accordian hose, and CBV is mounted. The coolant lines are run to the throttle body (sort of). But after seeing many pics and variations of the N/A to T swap, I'm very confused on vacuum routing.
I have, in place, the Mk3 3000 pipe, CBV, and accordian inlet hose, all of which I want to utilize. I'll list the lines I'm curious about:
The vacuum port on the bottom of the accordian hose
The two ports on the turbo - compressor housing and actuator (I want to use a mechanical boost controller)
The two lines that go to the PS pump/reservoir
Valve cover to TB PCV hose (presently capped at TB and filtered on valve cover)
Here's a pic of what I have now (don't laugh too hard, it's in the beginning stage)
http://www.imagestation.com/mypictu...e7444f5c86d71ee/fc247fda.jpg&caption=dsc00908
If anyone could help me with aome acceptable routing, I'd really appreciate it.
Donnie
What happened to the posting of this? Was it too old to keep? I am going turbo on an 85 5M with 5 lbs of boost, and after much digging found this article on the last page of a long search. Seems there is not full agreement as to where everything should go. Using 89 7MGTE as a reference, will run SAAB BOV from 3000 intake to accordion/elbow, add one way valve to brake booster hose, run catch can (split) connected from intake side of valve cover to accordion/elbow and to TB. Not sure what to do with power steering, the other hose connections on the accordion/elbow, and did I cover TB to PCV (don't know where that is).
Jeez, Donnie hasn't been around here for over a year. Are you asking about the vacuum line to the power steering pump? I deleted mine when I did the 5mgte. I don't see any question marks so I'm not actually sure if you are asking questions here or no.
To clarify, since there is no information in this post, all of the original questions still are requested. My first reply is what I know; the rest needs to be filled in, as this is new to me, please.
1 - 4 of 4 Posts
