Mine did. If you're really worried about it like I was...get some G2P emissions passer and dump that stuff in, go driving for a while before your smog check so your cat is heated up to the optimal operating temperature -JasonBonerdude said:will a 6mge be able to pass emissions in california?
I am wondering if you (pdupler) or anyone else has passed the new Austin / TX emissions with the 6MGE engine swap?pdupler said:Texas last year adopted the California style rules on emissions - specifically the ASM (Acceleration Simulation Mode) test for 1995 and older model cars. I am happy to report that my 6m-gte (including turbo) passed. Unlike California, they are not required do a visual here so my modifications were not scrutinized. A number of members have reported passing California emissions with otherwise stock appearance 6m motors. So long as you transfer all of the original EGR equipment to the 6m, and it is well tuned, I would think you should have no trouble.
Phil D.
Well you can use your 'marked' car emissions failure to diagnose where to watch out on the 6m. You will need the 5m EGR, but is it clogged?djgoop said:Anyone have suggestions on what to do during this swap to ensure passing the emissions? I have read about using the 5M EGR and upper manifold in this thread. Anything else I should look out for?
:stupid:pdupler said:Texas last year adopted the California style rules on emissions - specifically the ASM (Acceleration Simulation Mode) test for 1995 and older model cars. I am happy to report that my 6m-gte (including turbo) passed. Unlike California, they are not required do a visual here so my modifications were not scrutinized. A number of members have reported passing California emissions with otherwise stock appearance 6m motors. So long as you transfer all of the original EGR equipment to the 6m, and it is well tuned, I would think you should have no trouble.
Phil D.
In CA they do a visual, some inspection stations do a better job than others, if you fail visual it doesnt matter what the sniffer picks upCarlos Brown said:Gentlemen,
"Why would we expect a 6M to not pass emissions?" I understand that it does not come equipped with an EGR system, but do we really expect that the EGR system makes that big a difference?
Carlos
My 4runner failed the sniffer with a shot out EGR vac modulator, replaced the modulator and it passed.... so it's gotta be doing somethingCarlos Brown said:I tell you why I ask! The gas that is recirculated by the EGR system is a small amount of gas which passes from the #6 cylinder exhaust runner. The passage is about 1/2" in diameter and is positioned perpendicular to the flow. Also, the EGR system is only operable under certain conditions. Based on the fact that it only involves one cylinder, it is not exposed to more than 17% of the engine emissions. And of this 17% it will only recirculate a small amount...
Carlos
Ok, I will try and post those numbers tonight. They are in the glove box of my pride and joy, sitting in the garage pouting.Dangerous Ken said:Well you can use your 'marked' car emissions failure to diagnose where to watch out on the 6m. You will need the 5m EGR, but is it clogged?
Post the numbers ex (NOx : test number/ allowed limit) and you'll get suggestions on what to try Specifically.
Without numbers, you'll get pretty general answers.
Ken
djgoop said:Ok, I will try and post those numbers tonight. They are in the glove box of my pride and joy, sitting in the garage pouting.
Sean Chung said:wow, its been a while since I've looked at TSI test numbers, so used to looking at failed ASM tests since oct 04 when CA started using the dynos. How's your tune up, looking at the high hc at idle shows a lot of unburnt fuel coming out. Does your car idle smooth? Looking at the 2500 numbers, I would say its running rich, the idle numbers looks more like it has a slight misfire. Hard to say without looking at the car, though. Have you checked if the O2 sensor is reading correct?
Its been a while since I've had to diagnos smog failures, so I'm a little rusty at it.
Also EGR, functioning or not would not have any effect on these numbers, since egr only activates under a load. In CA, there is a functional check of the egr as part of the test.
