it will be interference. the valve reliefs are wrong on the 7m. use 82-83 5m pistons for stock compression or 84-85 5m pistons for ~9.6:1 compression.
william
william
I agree with William.. I have build a 5MGE head and 7MGTE bottom and used a 82-83 pistons to get the compression to 9.2 and sticked a 2mm headgasket on top of the.. BTW the car is running boost. Everything is A ok.williamb82 said:it will be interference. the valve reliefs are wrong on the 7m. use 82-83 5m pistons for stock compression or 84-85 5m pistons for ~9.6:1 compression.
william
