Hey guys i got a jdm 5mge and i took it apart to re-ring and put fresh bearings in it. Ran into a huge problem because the rods in the motor have the bearing tangs and oil ports in different locations than the US bearings
I work as a mechanic at Toyota dealership and when we looked up the parts number i noticed that Toyota 5M and 7M motor share the same part numbers for rod bearing.
1) Can i use a 7m rod with a 5m piston? Are they same length? Compression change?
2) Can i use a 7m rod with a 7mge piston? compression change?
3) Can i use a 7m rod with a 7mgte piston? compression?
Thanks
please only reply if u know for sure
Thanks
