1 - 5 of 5 Posts
I have a 5m flywheel and a 7mgte flywheel. Am I able to use either one and pair it up with a 7mge clutch kit to work on my w58? Also if anyone has a clutch kit they'd recommend i don't plan on making anywhere over 300 so something basic is fine, thanks.
Ltz, Ive been running an OEM 7MGE clutch setup with a HKS flywheel for well over 15+ yrs now...
IF you can find an OEM 7MGE pressure plate (heavier than the 5M version) I would go with a ACT street disc IF closer to 200HP.
You have to machine the 5M/7MGE flywheel if its been used...
7MGTE fly will NOT work...
IF you can find them get new flywheel bolts...
90105-10042
FW needs to match engine and trans. The 7MGT flywheel will be for M engine and R154 whereas the 5M flywheel will fit M engines and W58. Use that one.
1 - 5 of 5 Posts
