1 - 17 of 17 Posts
Hey guys, Its been a while. I have been doing plenty of work on MK2 supra as always, but not much on my own car as of late. I sold my 1UZ-FE auto swap, and my 7MGTE swap needs some work to get back on the road. Instead of fixing it up, I'm going to put all the knowledge I have gained from doing 2JZ swaps for others into updating my own supra. A lot of thought and research has gone into this. I also acquired a couple 2JZ engines back when they were still affordable. A quick overview so we know what is being updated:
2JZGE vvti block and head with 2JZGTE pistons and rods
Stock GE head gasket
Full ECUmaster Black standalone setup
Feramic full face clutch
Split cast turbo manifold
Borg Warner EFR 7163 T4 twin scroll w/ internal wastegate
The power goal is the same as the current 400HP 7MGTE setup, but with a street inspired torque curve. Small frame twin scroll T4 turbo with VVTi and hopefully around 9:1 compression should be fun on the street. I doubt I will need much more than 12 PSI to get there.
Currently, my own car is not in my garage because I am working on some other supras, so we are starting with the engine.
Automotive tire Motor vehicle Bumper Rim Vehicle
After tearing down all my 2JZ engines, the best one was from a nicely maintained and never opened Lexus.
Automotive tire Engineering Gas Machine Musical instrument
Torn down for machine shop. Bores have great cross hatch, bearings all still had almost all the coating intact. All I am going to have done is clean, deck, and some mild honing.
Motor vehicle Gas Funeral Machine Toolroom
I got lucky and all the rod sizes where perfectly matched to the used turbo rods I purchased. I am going to reuse the bearings that are in the engine since they were nearly perfect.
Automotive tire Gas Wood Automotive wheel system Nut
Cleaned up the turbo pistons and removed rings to prepare for reassembly.
Wood Building Automotive tire Gas Engineering
While the block is at the machine shop, went ahead and disassembled the low mileage JDM head someone donated to me. It was really clean. I am still taking it to the machine shop to be cleaned and checked, but it looks great.
Automotive tire Rectangle Gas Metal Auto part
I will clean up the valves like the pistons, but I am very pleased with the state of the head.
Machine shop was backed up, so patience will be required. Plenty of cleaning to do in the meantime.
Glad to see another old timer coming back!
Keep us posted 😊!
Looks like a neat build! I have a 7M in my 83 right now. So if you’re looking to sell any 7M bits let me know.
There will definitely be a lot of fun 7MGTE stuff for sale soon. This is an end to the era.
Have you considered any other turbos?
I spent quite a bit of time settling on this turbo. I have no idea if its going to work exactly the way I want, but it should support my HP goals and spool up quickly if I don't run into any other issues along the way.
Machine shop finished the engine work.
Automotive tire Wood Gas Auto part City
Cleaned and inspected block. Lightly skimmed surface and light hone on the bores. Cleaned and inspected head and skimmed the surface.
Wood Bumper Gas Automotive exterior Automotive tire
Started assembly to help clear out all the parts laying everywhere. Cleaned up and carefully matched all the main bearings back to their original location. You can see the two "4" marks if you look close at this set. That is the Toyota bearing size.
Wood Automotive tire Gas Machine Hand tool
I decided to keep the stock factory bearings. If you look closely at these you can see there is virtually no wear except on the edge of the seventh one.
Automotive tire Motor vehicle Bumper Automotive exterior Bicycle part
Cleaned and installed the top bearings in the block.
Musical instrument Gas Audio equipment Automotive exterior Auto part
Cleaned the crank and added assembly lube. Followed TSRM instructions to install it.
Fluid Drinkware Wood Plastic bottle Water bottle
I remember my dad used to have an old oil can similar to this. It was so useful. I finally just bought one and it makes lubricating parts and bolts so much easier while trying to keep everything clean. Highly recommend for the shop if you don't have one.
We are just getting started. Pistons and rods next.
Hey John,
Thanks for sharing the details of your 2JZ build and mentioning lessons from your Dad's shop. I too was a young benefactor of mentors that built motors and I now enjoy employing those skills learned with modern machine choices. I look forward to following your very interesting build here and seeing the running results.
Best of luck,
David
A couple minor slip ups while finishing the rotating assembly. This is my first time fully assembling an engine, so following the TSRM is invaluable. It also does not hurt that @Atl_Racer loaned me a couple nice tools to make this easier than buying or barrowing lesser tools. I also picked his brain a little bit when I was not sure about some things.
Automotive tire Kitchen appliance Cookware and bakeware Wood Home appliance
Putting on rings is tedious. Two rings have to be put on with a particular side up according to Hastings instructions. Then four of the five need to be clocked with the gaps at particular angles per TSRM. This took a while and required a lot of double checking because I like to be sure.
Mistake #1 - missed the laser mark on ring #2 and had to pull the first piston to check and flip it once I realized it.
Wood Fluid Bottle Gas Water bottle
With all the rings in place, apply the ring compressor and flip. Oil up the piston pin, install the bearing from the matching crank journal and add assembly lube.
Mistake #2 - I replaced one of the rods from the turbo pistons because it had a spun bearing. I offset the orientation of the rod and piston. When I installed it, the piston was correct but the rod was backwards. Had to pull it, drive out the pin, and flip the rod and reinstall.
Automotive tire Electronic instrument Automotive wheel system Wood Automotive design
Line up the crank, make sure the piston is oriented with the dot forward, and drive the piston into the bore. I found out keeping the compressor tool lined up, flat, and compressing it just the right amount makes this go smoothly... eventually.
Product Gear Wood Bicycle part Metal
Once in, push the piston down carefully until it is in place on the crank.
Wood Gas Font Tints and shades Landscape
Clean and install the matching bearing from that crank journal into the cap and apply assembly lube. Install and torque down according to the TSRM.
Automotive tire Motor vehicle Wood Automotive design Bicycle part
Double check all your work. The cap has uniquely oriented stamps ("R" in this case) to ensure you keep the matching cap with the rod.
Mistake #3 - Somehow, a couple of my rod caps got mixed up. I had to identify the correct rods and swap out the bearing and torque everything again.
Automotive tire Automotive engine gasket Engineering Auto part Wood
DONE. Rotated around a couple times to make sure it moves smoothly. I can tell those rings are ready to start breaking in.
I talked about my mishaps because everyone is not perfect. As someone who has not done this a lot, it was crucial to constantly doublecheck myself. Mistakes are generally OK, as long as you catch and correct them. I really enjoyed this and find it really rewarding to get it all right... eventually.
Reassemble the head next.
Put the head back together today.
Motor vehicle Gas Font Auto part Engineering
Installed the new valve seals and valves. Springs ready to be popped in.
Building Urban design Window Engineering Tower
All the valves and keepers installed. This has to be the first time I managed not to lose a keeper.
Wood Automotive exterior Font Gas Engineering
Cleaned all the caps and shims and installed. I can't check the clearance until I install the cams, which also can't happen until I torque down the head.
Wheel Automotive tire Motor vehicle Wood Bicycle
Block and head carefully cleaned and ready for the head gasket.
I put on the metal head gasket and grabbed the new Mahle head bolts I purchased to torque the head down. The bolts quality looked suspect despite the brand name, and they did not have new washers. I went ahead and followed the TSRM procedure to torque down the head with the old washers, but I did not like the feel of the bolts stretching while torqueing it down. Its felt too uneven and made me nervous. This probably would have been OK, but I could not take it. I un-torqued the head and ordered ARP studs. Expensive, but can't go wrong. Plus Amazon will have them here tomorrow.
Discussion Starter · #12 ·
Product Human body Cosmetics Material property Cylinder
Following up on the head bolts. Left is used OEM bolt, Then a new ARP stud, then 3 used Mahle head bolts. I think the picture mostly speaks for itself, but notice the 3 bolts don't even have uniform tips.
I installed the ARP bolts, but I did not have a deep 16 point 1/2 socket to torque them down. So in the meantime...
Automotive wheel system Auto part Circle Rim Metal
I rebuilt the VVTi pulley. The o-ring frequently leaks when it gets older. This one broke into pieces when I separated it, which took a hammer. Lot of documentation for doing this online.
Dead bolt Door Gas Circle Auto part
Ready for when the cams go back in.
Reactions: dannoxyz
Discussion Starter · #14 ·
I am behind on my updates, so here is some of it. Many thanks to Tommy again for loaning me the tool to get this done. Made quick work of the ARP head studs and feel much better about the head being torqued down.
I also wanted to talk quickly about what this all amounts to. Turbo pistons and rods + 2JZGE head gasket + 2JZGE head will give me a stout bottom end with slightly higher than 9:1 compression ratio. The original GE compression ratio is much higher, but the turbo pistons bring the ratio down and keeps the squish reasonable. This compression puts me between GTE and GE, and will work well since I do not plan to push much boost.
Automotive tire Motor vehicle Engineering Automotive exterior Automotive wheel system
Once the head was on, I could install the cams. The TSRM has an extremely long process for this that took a whole evening of effort. This makes sure the cams do not get stressed and are all tightened down evenly. Some people not paying attention have managed to damage cams when not being careful.
Engineering Gas Machine Auto part Metal
A shot of the cams fully installed.
Light Camshaft Gas Engineering Automotive wheel system
Next I went through and checked all the valve clearances. I must have kept the caps all straight and be a lucky guy, because they were all within spec. I'll take the win.
Bottle Engineering Gas Water bottle Machine
Installed the cam seals. In the next post, I'll put lots of parts back on the front of the engine.
OK, lots of FIPG ahead. And so much gasket surface cleaning...
Automotive tire Motor vehicle Bicycle part Wood Rim
New rear main seal and installed the retainer plate.
Automotive tire Motor vehicle Hood Asphalt Rim
Brand new oil pump with a new front main seal.
Automotive tire Hood Motor vehicle Automotive exterior Bumper
Upper oil pan. This took a while to clean and apply all the FIPG.
Crankset Automotive lighting Automotive tire Motor vehicle Rim
Baffle plate and oil pickup.
Automotive tail & brake light Grille Automotive tire Hood Automotive lighting
Brand new lower oil pan. It was so cheap I could not resist replacing the banged up one that would need a LOT of cleaning before being used.
Automotive tire Motor vehicle Automotive exterior Rim Bicycle part
New water pump with all the o-rings and pipes that connect to it. I'm glad I was paying attention to the TSRM because I wanted to put the timing belt on and this has to come first.
Motor vehicle Automotive design Engineering Automotive tire Gas
Added cam gears and roller. Lined everything up and put the timing belt on. Rotated it a bunch of times and everything lines up.
Engineering Wood Machine Electronic engineering Computer hardware
Last thing I want to do to seal up the engine is install the valve covers. These will come off again to add oil later, but they will keep out dirt for now. This is what they looked like when I took them off the engine. I tried to clean them several ways and they still looked ugly.
Wood Bumper Automotive exterior Automotive tire Gas
And here is what they look like after I sent them to the guys at JP3 Motorsports and had them vapor honed vaporhone.com I was really impressed with their work.
Motor vehicle Automotive air manifold Automotive design Gas Automotive tire
One more shot of the complete engine. There may be a quick break from updates while I wait to get my car back. The 7MGTE will come out and I can test fit the 2JZ and start rebuilding the R154.
Reactions: Atl_Racer
1 - 17 of 17 Posts
