Aluminum Radiator Group Buy
  • Yes, I'm ready to buy now.
    Votes: 0 0.0%
  • Total voters
    1
1 - 20 of 47 Posts
Description: 2" core, with 2 rows of aluminum tubing.
MK3 style end tanks. Two upper tangs to mount to factory location.
Possible extra features: Mounting holes for flex-a-lite dual fan,
and / or duplication of hole positions like the factory. Transmission
cooler threaded plugs.
Possible options: anodized black or clear.
Fitment: The upper tank inlet is offset about 1-2" from factory.
It will require a modified upper hose for a 5/6M. The factory
mounts *may* require some minor modification.
Minimum quantity: 20
Price: $250-300 (currently in negotiation)
Final details in next post.
I would like to be in depending on time frame and havent voted due to not knowing.
The question I have is this radiator ideal for a 7mgte swap? Would it provide enough cooling capacity?
You can bet your asteroid I'm still in for this.
Money talks, I should know, mine always says, "goodbye."
Scott
jdk_ii said:
Timeframe is probably late September.
Yes, this radiator is intended for 7MGTE swaps.
I don't plan on a 7MGTE swap, but rather looking at the better radiator as a great improvement to any MkII. Can't think of may 'performance' mods that extend the Longevity of an engine; especially an engine known to need head bolt tightening and metal head gaskets...
Ken
I want 1. Is the inlet closer to the battery or the center? Battery side would be better for those with the scooped C/F hood. Thanks Later
1 - 20 of 47 Posts
