1 - 5 of 5 Posts
Are you planning an '84-'85 5 MGE engine swap?
ECU ..WITH those wiring harnesses will work fine.
'83 ECU is different as is the wiring harness.
There will be other differences going from'83 to '84-'85 engine.
Vacuum hoses,for one.
Your '83 external fuel pump MAY work.
The Megasquirt uses a minimal number of sensors to run the engine, so a lot of any year engine harness will be unused.
85 ecu is only different in that the TPS is full range, otherwise not much gain. If you go standalone yeah jsut do whatever you want. Add/remove wires at your leisure to make it all work, though it is no small task.
1 - 5 of 5 Posts
