1 - 2 of 2 Posts
I'm putting a 6M in my 83. To switch to the 84+ style alt plug, I need to do what? Get a plug from an 84+ and switch it with the squarish 83? The plug configurations look the same, but are the wires the same?
Thanks,
Nick
I'm not exactly sure, but I think the alternator plug wiring color code may be different between the 83 & 84? As long as you get the color code right, swapping the plug is okay, but you'll have to do the diode mod. where you remove the charge light relay and install a rectifier diode in the relay socket if you want to use the 84 alt. in your 83.
1 - 2 of 2 Posts
