1 - 8 of 8 Posts
This is my second supra my first was an 84 with the 5mge, 5 speed manual. I put a cold air intake on it and put lowering springs on it. But I had to sell it and I was devastated. So I tracked this one down and I'm not getting rid of it. So I need help and some ideas about what to do first. Thanks to all
And I'm looking for parts for sale, and any Ideas to get around 200hp.
well you can change your intake system out
i mean you have a more restricted intake from the air plemnum to the block
i have the later model intake system minus the throttle body for sale
you can gain some hp :)
Get in the Sub-Forums and read for about 2 months, then use the Search function and read for a few more months. You need a better understanding of you car so you can understand what modifications do what. And I know that you had one previously, but if you took the time to understand the car back then, you would not be starting this thread now.
Hell, when I started 7 years ago on the Celipra, there was barely anything out there, and I still researched and read for a while before digging into the car. For the most part anytime I want to upgrade the Celipra, I do my reading.
set your budget first. Then your goals for the car.
Foremost you can probably spend some $ on replaceing 25= year old bushings, suspension parts, belts, bearings etc.
If you win the lottery just look for a guy called dave on the forums and copy all the things he has done.
I've been super charging Camaros before this I understand what to look for I just want to know if anyone has parts for sale or something u tried before thats a bolt on I have quite the fund to mod with so let me know.
I have a RRFPR that would be needed for a Super/turbocharger setup. And Oil Lines for a CT26 Turbo(stock ma70 turbo that most peps start off with).
1 - 8 of 8 Posts
