1 - 6 of 6 Posts
It may be helpful to state your location and front or rear. Need the entire assembly? Just the outer cover/lens?
Discussion Starter #3
Sorry. Front left turn signal/corner marker. Whole assembly but harness is not a must. Im located southwest Florida.
I have the lens only if that will help you. I used the back side of the housing assembly to put a euro style lenses in. I was able to pry out the lens itself after boiling in hot water for a few minutes to melt the adhesive.
15164
15163
Discussion Starter #5
Need the whole housing unfortunately. Thanks though. I might of found one on Ebay. Just waiting on the seller to send me a picture of the back casing to see if it is marked left
The lens itself also has an R or L in the bottom corner in case the seller has pics of the lens that you can see.
1 - 6 of 6 Posts
