1 - 20 of 63 Posts
· Premium Member
'85 Toyota Celica Supra P-Type
attached photos are from Zen Graphics and thought Raptor Racing had them also before though maybe I am overlooking them now
may be a while until I paint my car and working on quite a bit of mechanical issues including but not limited to my hood cable coming loose under the hood yet again
will be looking for placement of lettering along with what color the black P-Type used
also, trying to decide if I want to go with the large lettering or the more subtle - curious also the history behind the two different ones
thank you
Wheel Tire Automotive parking light Vehicle Car
Automotive parking light Automotive tail & brake light Vehicle Automotive lighting Car
Car Vehicle Land vehicle Automotive parking light Hood
· Premium Member
The 82-83 had the ‘subtle’ style and the 84-86 had the billboard. The billboard in your photo above is positioned too high
will post a pic of my car, the pics are from the Zen Graphics website and I was told mine is too high also
sent using Tapatalk
1983 Celica Supra P Type Manual 80k original
Mine is an 83 which should have what you put on. As I recall (same as Spud said,) they had the smaller "Celica Supra" lettering on the right through 83 and then went to the big billboard in 84. But I put the big, billboard on mine anyway because that's what I remember seeing on these as a kid and I thought it was cool. Yours being an 85 would have had the big, billboard but what you have done looks great and I am a big zen graphics fan. Their choices and quality are top notch. It was the only place I found that could do two tone with a main color and a border if you want it. Love mine. Looks good but choices choices. If you go billboard there is the one person on eBay that does the translucent design and one on etsy that does the non-translucent but a bit more correct. I went with the ebay gold translucent as it looks cool in the dark and still matches my gold well enough in the day. If you do the billboard my tip is to measure top to bottom and the sides and mark them off with blue tape so you can line it up will. You may have to trim around the keyhole on the hatch and should if you have it lined up correctly per stock (again in agreement with Spud)...they were positioned a bit lower and trimmed a bit around the "P" on the keyhole.
· Premium Member
please post pics when you can and I will post some of my current when I can
thank you
sent using Tapatalk
thank you
sent using Tapatalk
Mine is probably even slightly high per stock but I liked this positioning. If it doesn't go over the keyhole a little it doesn't quite look right. My tail lights are a dead giveaway that it's an 83 and should have the other graphics but I don't care, I wanted the billboard and only someone on here would ever know. Both of those sources...the eBay and the etsy people do them in multiple colors so pick your favorite. I actually ordered both. Again the eBay is translucent (reflective at night) but the etsy is slightly more original looking and that seller gave me two as well so you get a backup in case you mess up!
Automotive parking light Vehicle Hood Automotive side marker light Motor vehicle
Automotive tail & brake light Vehicle Bumper Automotive lighting Automotive exterior
Tire Wheel Vehicle Car Land vehicle
· Premium Member
I like the contrast on yours. Makes me consider possibly red on my black. Do you know what the OEM was on the black? I would have thought silver or white. Thank you again.
sent using Tapatalk
Hmmm? I'm not sure what the OEM billboard lettering color would have been on black in those years. Maybe someone here knows? I'm guessing white or gray / silver. I will say I have seen red on black but depending on the color of red it can get a bit buried in the black...not a ton of contrast with if you get the wrong red. on the other hand, the red would match the Celica Supra logos well.
LifeForLife's black 85 has red pinstripe that looks great, so maybe that color red in the lettering and then red pinstripe or hockey stripe graphics of the same red would be sharp. A sharp, bright red is what is needed, not a darker red that blends with the black too much in my opinion. See LifeForLife's current build thread. He went with a white billboard though. Maybe you could get one of the ebay or etsy sellers to do it red with a white border then the red / white pinstripe like LifeForLife's. That would be sharp.
· Premium Member
Gray may make more sense than silver.
Will see if anyone else replies regarding color lettering on black body color.
I did see someone with a nice red pinstripe or maybe it was a hockey stripe on black that I liked.
Much appreciated.
sent using Tapatalk
· Super Moderator
Do a thread search on Billboard, you will see many exemples of color and position.
iirc, on black cars they were gray.
Correct, dark vehicles were grey, light colored vehicles were black, silver vehicles were also grey. Only two colors that came from the factory for the billboard decals.
I've never produced the smaller sets for the early models, but have done a bunch of other versions, including the Celica XX decals and the black banner style (still unconfirmed if any of these were oem).
For installation, its much easier to just pull the lock out of the hatch and install over the hole exactly where it should be, rather than trying to cut around the lock. You can then just slide the lock back in and have the decal tucked under the rubber/plastic gasket of the lock. Takes an extra 5 minutes to pull lock and reinstall it and looks much more professional.
Celica XX in met. silver:
Automotive tail & brake light Vehicle registration plate Automotive parking light Car Vehicle
Import reproduction, digital printed over met. gold:
Automotive parking light Automotive tail & brake light Vehicle registration plate Car Vehicle
6MGTE variant, definitely not oem:
Automotive parking light Car Land vehicle Vehicle Wheel
Above is based of this vehicle from the late 80's:
Automotive parking light Automotive tail & brake light Vehicle Car Wheel
And no, I don't have any contact with the owner of the red car, that was a photo from waaaaay back when. Don't even know the owner's name any more.
· Premium Member
Vehicle Land vehicle Vehicle registration plate Car Automotive lighting
not the best one, but took from my intro thread a while back which was a picture the previous owner had
will take some others when I get back to the car tonight
1 - 20 of 63 Posts
