Ok, I have 3 mkii.
This one has been giving problems since it got home. It got issues dam it.
Since the day I got it, it has been sitting there. I tried all I can and still come out short. I am not going to bore you of what has been done. I am going to tell you what is wrong with it now. Here it goes..
It starts right up idle smooth when warm. I slowlllly rev up or speed to about 65. It speeds up like a mopad pulling 5000 lbs weight. I did the injectors, fuel pump and filter, timing, tps, and afm. I thinking of bypass the wire of the tps straight to the ecu. And the same with the afm. Ideas please.
thanks!
thanks!
