1 - 5 of 5 Posts
everything turns on fine and when i go to turn on the lights the lights themselves turn on they just don't flip up. i'm thinking fuse?
check your horn fuse.......does your horn work, i'd check all your fuses, but one time my horn pad was stuck on and i removed the horn fuse and my lights didn't work.........didn't pop up....so i'd check that first
which is the horn fuse?
ok... so i went out and checked all the fuses and all looked fine.
i even pressed the horn and it still worked.
I just went through this on mine.. I replaced the small blue box underneath the dash next to the steering column.. didnt help
It was the Relay next to the engine bay light on the passenger side in the engine bay next to the shock tower.
1 - 5 of 5 Posts
