1 - 1 of 1 Posts
When I picked up the 85 in Cali-First thing I noticed opening hood is No AC Belt-Have been messing with it off and on and heres where I am-Replaced Belt-Replaced Fuses-Replaced switch-Now I have power thru switch and when I jump compressor direct the fan clutch turns on-however, switch doesnt turn system on-So power not getting to clutch-In TSRM they list a pressure switch between switch and compressor without describing function-If this is a Low pressure cut off then my system is probably completely discharged-But if this is a sensor, then is it just bad, hence no juice-Any Thoughts?-Mike P-(I would be soooo bored without things to fix on my car!)
1 - 1 of 1 Posts
