1 - 6 of 6 Posts
finally i put the dash back, im trying to plug the a/c switch back, but the harness is completely different, there is no more harnesses around ( just theose ones for the radio) look at the pic n u will see.
so do a need a different a/c switch? if u have it lmk i need it asap.
like the switch or the harness ?
They did change them but Im not 100% sure at what year. I think it was in the 85-86 models. I will look and see if I have a Spare.
They changed the switch for the 85/86 model. I just did a swap from an 83 to and 85 and noticed the switches were different. During the swap I found the radio surround piece with switch in a junk yard from and 84 and it also had the old style switch. To remove the switch is easy to do and will fit without problems. I have an old style switch if you need one.
thanks guys, yeah i did the swap too, body is an 84 auto, now with an 85 5mge 5 speed, and yes the ac switch in the pics is off my donor 85, so nothing will change if i just replace the switch? i mean they r like 5 or 6 pins on the 85 switch (why), still both automatic climate systems right?
1 - 6 of 6 Posts
