Does the upper section of the header interfere? If its just the lower section (Ypipe back), then take that as an opportunity to rebuild that entire piece. The OBX is decent, except for the fact that the final down pipe is a paltry 2 inchs in diameter, just like the stock exhaust :eekfacepalm:
It's mainly the back 3 hitting the steering knuckles - call them 4 - 5 -6. Number 3 fouls the knuckle too, just where it crosses under 4 -5-6. Only ones that kinda work would be the first two! In hindsight i maybe should have bought the OBX 7MGE manifold (umm sorry, header
) as that is easier to mod.
And some updates...
I Bought a 4 litre kit of U Pol Raptor Truck bed liner for the underside o the car. Fully impressed with it!
That shits unscratchable it seems, and goes on lovely with a shultz gun on a compressor. Tigersealed the seams beforehand so hopefully it should last
[/url]
SAM_2705 by
neil walker, on Flickr[/IMG]
Used about 3 Litres of raptor on the underneath, so had a bit left to do the insides in places most likely to wear. The footwells have a nice waterproof and grippy surface now. The rest of the inside is going silver.
[IMG
SAM_2707 by
I also did the boot floor with what i had left. Quite glad i did as it really tidies it up a lot
[/url]
SAM_2710 by
[/url]
SAM_2711 by
I have started to plumb up the new fuel system. The whole car is using 8mm ptfe lined braided stainless hose & AN6 fittings. All apart from the fuel cell and swirl pot - which are AN8, but thought this a bit overkill and meant buying lots of different fittings and hose, so keep it simple stupid i thought. The Lift pump from the Fuel cell is a Facet Red top, and the main pump is a Walbro GSL392, Which flows 255 LPH
[IMG
SAM_2721 by
Placement of the Walbro Fuel pump and Bosch fuel filter is causing a bit of head scratching at the moment. I quite like this position as it's close to the swirl pot, and well out of the way of damage, but will have a play about before i drill any holes!
[/url]
SAM_2717 by
I bought some AN6 through Bulkhead fittings for joining up the fuel lines from the underside of the car. I didn't want to run the lines through with grommets around the hose as think thats a bit sketchy. This sits under the diff carrier subframe so well out the way and close to the swirl pot
[/url]
SAM_2720 by
Screwed on some 90 deg fittings, but looking at it, Straight ones are better
[/url]
SAM_2719 by
Once i figure out where the main fuel pump and filter is going, i'll do the rest of the lines.
[/url]
SAM_2716 by
I also made this dry break style filler a while ago. for the jgtc tyte look yo. hehehe:zzzzz:
[IMG
SAM_2699 by
[IMG
SAM_2697 by
[/url]
SAM_2696 by
Filler neck on the jaz fuel cell is quite tall so might chop a few cm off it to lower the angle
[/url]
SAM_2698 by
Did some work to the dashboard in preparation for Car trimming wonderwoman Nicky to sprinkle some skill over it. Ordered a length of Black proper job Alcantara cloth to cover up the skanky old blue, so before i used some of the the dry carbon honeycomb dashboard that Amy's better half gave me, These Holes are for the AEM Wideband and Boost gauge, but have also ordered Oil pressure and temp gauges too.
[/url]
SAM_2722 by
Where the heater vents for the side windows used to live, i cleaned up the corner that fouled the cage and boxed it in with some dry carbon fibre. A lot tidier.
[IMG
SAM_2725 by
A wider shot so you can see the honeycomb and the tidied up corner
[/url]
SAM_2723 by
The underside is nearly there, Just the diff and prop to fit really, but wanted to do the fuel lines first before putting them back in.
[/url]
SAM_2730 by
