Title says it all: I have an '82 Supra. It currently doesn't pass smog due to what seems to be engine issues. I have never worked on a car, but I'm willing to get quite dirty to get it to work and work right.
I figure I should post my progress somewhere, and I think here is the best place for them, not only for you all to comment on what I should do, but for me to keep myself on track as well.
As of 29/4/2022, here are the things that need to be done:
29/4/2022: Here is my current worry: Engine is making noises that I deem a red flag. Not sure what it is, but it makes my heart sink.
Heater hose from the top, back of the engine popped and needs to be replaced.Done on 22/4/2022.- Coolant flush. Drain the mineral waterthat is currently in the system and put some proper stuff in there.
- 29/4/2022: Got some Toyota Red and distilled water, and the car is now parked inside on a flat area. Will have to ask my neighbors if they have a jack and jack stands I can use.
- 30/4/2022: Neighbor did have a jack and jack stands. Messed up a bit on the coolant burping process, and overflowed the overflow tank. The car still overheats (the bar on the digital dash went over the middle mark), so I'll be getting a new thermostat. The car, with the new coolant, is still throwing clouds of smoke even when warmed up, so I think the head gasket is kaput.
- Check to see if the car still overheats.
- If so, check thermostat. Replace it if necessary.
- Diagnose the engine and its issues: Compression check, dry then wet. Maybe a leak down as well. Cyl. 4 has compression so low it isn't burning the fuel right, and Cyl 3 & 6 also has a bit of low compression, according to previous owner's service check.
- The fix:
- If piston rings aren't the issue, the head is most likely coming off and the head gasket should be replaced. Valves should be checked, and the valve seals should be replaced. Reseal cam tower.
- If piston rings are an issue, or the head is cracked: uh oh...
- Smog check
- If the car still does not pass smog, check timing and the vacuum advance distributors. Something to do with the diaphragm?
- When everything goes well, all coolant/heater hoses should be replaced. Same goes for all vacuum lines.
- The alternator should be upgraded. As of now, I need to jump the car to get it to start.
- Miscellaneous things that should be fixed (after the car passes Smog):
- Throttle pedal feels super wooden and feels like a lot of friction is holding the pedal in wherever it is.
- Heater fan doesn't work unless it's on high, and when it is on it makes a very loud noise. Probably something about the fan.
Hood struts are bad and should be replaced.Done on 20/4/2022.- Hazards don't activate. (Switch doesn't work)
- Seat belts don't retract easily.
- Driver seat (cloth) should be cleaned and the rip on the side should be fixed.
- Passenger side window does not work.
- Steering wheel leather is all cracked and should be replaced.
- Left rear turning lights have a crack in it.
- Map light doesn't work.
- What I want to do to the car, after all the fix:
- The ceiling light (I have no idea what it's actually called) is quite dim -- probably an old-car thing and how it should be, but I want it to be brighter.
- Speakers probably should be replaced with newer ones. I will still use the stock head unit but the speakers in the car might be shot. Something, something, install subwoofer? (I don't think my car has it. Might just be an idiot tho.)
- The pin stripe should either be removed or fixed.
- Clean the car thoroughly.
- Buy a dash cover, as well as floor mats.
- Get an audio jack to cassette converter to play some tunes.
