1 - 20 of 22 Posts
I am back with yet another electrical issue on my '83 restoration. This time it is the AC. I contemplated not reinstalling any of the AC during the restore; however, I do like creature comforts so I opted to restore the AC system also. The only issue is I cannot get the AC Clutch to kick on. Applying power to the clutch manually with a jumper wire from the battery and it works okay. Therefore I know the compressor/clutch is okay but somewhere there is an electrical problem and no power is getting sent to the clutch.
Here's what I have done so far...
Replaced with all new components:
AC Compressor w/clutch
All AC Lines
Receiver/Drier
Evaporator Core
Expansion Valve
Pressure Switch (inside evap box)
Blower Resistor (on side of evap box)
10A AC fuse in the passenger kick panel
AC Relay (used from donor car)
and fixed all leaks. :ugh:
Did not replace:
Condensor (flushed but did not replace)
EPR valve (scared to crack the seal on this baby)
External Ambient Temp sensor ohm check is okay (.45)
Have not checked:
Solar Sensor on dash
Internal Temp sensor under the console
Vacuumed down system for over an hour and then charged with 1.5 cans of R134 Freon (converted from R12...unfortunately). A few bubbles still exist in the site glass but I think that would be enough freon in it to trip the pressure switch (I think).
The blower works fine and will blow decent cool air plus there is a big temp difference between the suction and pressure AC lines when the clutch is engaged manually.
I have researched this pretty well in the TSRM and on the forum but cannot seem to locate the issue.
Does anyone know of any tests that I can run to test circuitry? Is there another fuse, relay, circuit breaker that I have not found yet? I noticed several test connectors under the passenger dash. Don't know if they are related or not and cannot find any information on it.
Any assistance is well received and appreciated.
Mark
so... if u put a 12v wire at the compressor wire wont kick ???? is a new r used compressor? maybe there is not enough freon, maybe your ac switch is bad.
how do u know u still have freon on the system? do u have gauges on the low and high pressure side?
Discussion Starter #5
I am only know that there were no vacuum leaks. Multiple vacuum tests indicated good vacuum for over 24hrs. I know that's not a 100% test but it's all I got. I assumed that 1.5 cans of freon would have tripped the switch. Your thoughts?
ok, if u letave the live 12v wire on the compressor, does it get cold inside? what is the air temperature coming out the vents????? in r-134 must be around 40 degrees, if u r not getting that maybe is not enough freon to activate the compressor.
Discussion Starter #7
AC Pressure
To help answer the freon question I installed my gauges and took the following pics. During both readings the gauges were steady except for slight fluctuations (+/-7 to8 psi) on the low pressure side. I'm not exactly sure what the correct readings should be for an R134 retro system but does this help? Should this amount of pressure trip the clutch switch?
1. Pic of guages while engine uncranked or cranked WITHOUT clutch manually engaged.
[/IMG]
2. Pic of guages while engine cranked WITH clutch manually engaged.
probably not so simple, but, did you remember to connect the compressor's electrical plug - brown plug one wire(on 82's it's off the main harness, 83?)
mmm for me its way too low...the capacity is around 24 oz +/- ....
Discussion Starter #10
Sorry, I had to leave for the afternoon.
I looked up the AC specs in the TSRM and the LOW side seems high and HIGH side seems very low. Not exactly sure what that means other than the system still isn't charged correctly.
I will try and pump more freon into it tomorrow night and see what happens. Unfortunately I do not have an attachment that I can charge using my gauges so I'll have to do trial and error until I get it up the charge. Anyone with ideas on why the gauge reading is so odd, please chime in.
Thanks!
could be a bad expansion valve.
It looks like it's not pumping. The low side should be dropping when you engage the clutch. R-134 pressures read higher that R-12 systems. It is possible you have a stuck open expansion valve, and the freon is just circulating without changing states.
thats what i see. gauge didnt drop at all.
Discussion Starter #15
Thanks for all the advice. That could be why it does not seem to want to take freon... there does not seem to be a lot of suction. Of course, the expansion valve is in worse possible place :). Is there a dfinitive way to test the expansion valve before I tear the evap box back out? Or is the gauge test, THE TEST.
Thanks again...
to take the evap is not soo bad, heater is a pita job. i have a new expansion valve for $35 + shipping. (1 year warranty)
Discussion Starter #17
I was fooling with headlights tonight so I didn't get around to the AC. Also, I am trying to find a R134 Can Tap to allow me to charge while the gauges are attached. Hopefully tomorrow.
zuprax85... What brand is the exp valve that you have?
not sure if is a 4season , ill check them tomorrow.
Just an off idea, is the fan running in front of the condenser (the radiator for the AC system)? This is the fan that is forward to the front support brace, in front of the radiator.
Discussion Starter #20
Yes, the condenser fan is running. In fact, it almost took a finger off :)
One other thing if it helps, when I engage the AC switch the RPMs do increase. So I would think that and the fact that the condenser fan is running it would rule out the AC switch.
Does anyone know how to override the Pressure switch? Is there a test connector for that?
1 - 20 of 22 Posts
