RE: the need for add'l PCV breathers for a 5mgte, I finally got a look at a 7mgte oil breather layout. To do the same for a 5mgte, it seems as if I could use a T hose connection for the intake side hose to connect the throttle body and intake valve cover, but what can be done for the exhaust side valve cover. Could I drill it and put a fitting in it making it like the 7mgte?
I know Phil used a hole in an oil cap to rig a vent to air with a catch can. Did that work well enough?
What would be other ways to add breathing/venting?
