Yeah, Ive seen those kits for the ae86 on a couple of japanese websites. Lemmie see if I could find that site. I lost all of my bookmarks, so I have to search for it again.Racefiend said:There actually are a few kits offered but they are in Japan. THey are actually for ae86's but our setup is the same so it should work no problem. Basically all it is is a threaded spring perch which fits over the shock (you need to weld a stop ring onto the shock). The top gets a spring hat which kinda looks like a dunce cap. It lets the top of the spring mount lower than the top of the strut tower (sice the strut tower is so narrow, you cant filt a spring up there). They have a similar setup here in US for 1600 and 2002 bmw's, but it may need some modding to work on our mk2's.
Personally I wouldn't use that setup without at least a rear strut bar.
white_mk_2 said:I think I've found the solution to this. An adjustable perch for the rear springs that keeps them independently mounted from shocks (not coilover) like stock.
http://photos.yahoo.com/bc/white_mk_2/lst?.dir=/Rear+spring+adj+perch&.view=t
Hey This guy has done the 5 bolt conversion also!
The kits TomD was refering too are actually for Honda Civics. They are on Ebay for 60 - 90 dollars. You have to cut the spring perch off the front strut and weld the coil-over sleeve on the the strut housing. I guess the rears would have to be attached also. If it works it would solve alot of problems.
-Wil
dohc82 said:I wish, actually it's a pic of a Volvo with the adjustable rear spring perches I mentioned.white_mk_2 said:I think I've found the solution to this. An adjustable perch for the rear springs that keeps them independently mounted from shocks (not coilover) like stock.
Diameter isn't the problem with finding tires for our car, its the rim size combined with the tire diameter. AE86s have a diameter of around 22 inchs so a 195/50-15 works great, and theres tons of selection in that size, same with 205s and 185s. Lots in 225/50-15s as well which is a nice supra size but just a little on the small side if gas milage or a 100 percent accurate speedo is important to you.white_mk_2 said:Yeah, nothing bigger than 15"plenty wide though, they must have a way better selection of smaller diameter tires in Japan.
