Quasi unobtanium items.
Tokico Illumina 5-way adjustable shocks.
Fronts: BZ3062
Rear: BE2321
Notes: (Fronts). The BZ3062's are LONG discontinued & are pretty much impossible to find. Right now, your only option is to use the ones for the MKIII RA Celica, which is part# BZ3074. They will still work, but they will have a softer dampening rate for the weight of the Celica's. Just means you have to turn up the stiffness up a notch.
P.S. For those of you that are about to ask "Why can't Tokico make more of these"????? It's been discussed YEARS ago!!!! Run a search... Type in "Tokico Illumina" & look for postings from Chris Clement (Flyin Hawaiian). Bottom line is that Tokico destroyed the tooling to make the BZ3062's & they won't ever be made again.
(Rears). The rear shocks are the same ones that are used for the RA Celica as well.
Both front/rear items are "quasi" still around... You just have to do some dilligent investigating. Toysport still had a small selection, but they'll also charge you an arm + a leg for them.
As some of you know, Shawn P (junkie) had a set of the TRD 7-way adjustable's (made by KYB) F/S several weeks ago & I believe someone jumped on these within 2 days.
