1 - 5 of 5 Posts
Has anyone tried the split second afm conversion? I know they really wake up a 22re, and LCEngineering says it will work on the 5mge as well. The kit cost about $1k. So kinda pricey, but if it gives the 22r 13hp and 20+trq to the wheels on a stock 4 banger should do wonders for a l6.
There was a group buy here quite a while ago but I don't think anyone ended up really happy with it. Do a quick search and I'm sure you'll find some threads on it...
i'd never spend a grand on a kit that only does 1 thing. for less you can get megasquirt which has the same option to use a map sensor as well as everything else you need. the afm isn't really holding this engine back though and with the option to use the lexus afm and larger injectors (if needed) really makes it more beneficial for the money.
get yourself a chimpy intake and you'll free up a lot right there. that's where the restriction is, in the stock plastic pipeing.
If you search back a couple of years, you will see lots of talk about it. Since then, most people have given up
I know it's an old topic, but I'm interested to see if anyone is STILL running the split second setup. Just about everybody sold their setup, and/or had some sort of issue. The software is not the greatest. It does remove the AFM though, if that is your goal.
I'll save you some time and post links to the old threads. Do not reply in these threads, the last thing we need to do is bump 3 year old threads.
my thread regarding install and issues:
http://forums.celicasupra.com/showthread.php?t=15452
another long split second thread:
http://forums.celicasupra.com/showthread.php?t=12478
1 - 5 of 5 Posts
