oil pump sounds like it went. common thing with our cars got any videos of it running? My car had similar issue but it turned out to be a misfire from bad timing.
Thanks. Unfortunately the engine will not start again.oil pump sounds like it went. common thing with our cars got any videos of it running? My car had similar issue but it turned out to be a misfire from bad timing.
Oil level is fine, about half way on stickCheck oil level and report.
Thanks folks!So, at this point, pull the plugs out and see if you can turn the engine by hand--I assume you know how to do that with a socket and wrench on the crankshaft bolt. If it is completely locked up, you will need to investigate further. Next would be to see if you can turn it over again by hand after removing the timing belt. This will tell you if you seized a piston or broke the crank if you still cannot get it to move. If you can, then its a camshaft/valve that's gone bad. You can then move to the cams and see which one does not turn at all.
To be determined. Took to my local mech. And they are disecting the oil filter and removing pan. Thx!Any sparkly metal particles in the oil like a 1970's low rider paint job?
Please report back with results. Sorry for your troubles, best wishes on the repairs/rebuild.To be determined. Took to my local mech. And they are disecting the oil filter and removing pan. Thx!
