1 - 19 of 19 Posts
hey can any one tell me if there is a certain part number from summitt or jegs for the mendrel innercooler piping. i am running a ct26 and a stock 7mgte innercooler.
also is there a certain rrfpr i am needing as i am installing all this into a 6m. and blow off valve?
the only specific intercooler kit that ive seen for the mk2 is from rabid chimp. other then that i think you need a universal kit and you need to cut the pipes to fit. maybe the mk3 kits are easier to work with? not sure. i think most on here like the begi 2025 for the rrfpr, and as far as BOV, most will tell you a stock bosch.
I Know for a fact that the mk3 intercooler and pipping fit into the mk2. I'm running a 1jz with the stock intercooler pipping and it fits. So i'm sure the same pipping for a 7mgte or wtv will also fit. Good luck.
i know the stock mk3 intercooler fits with minor modification, as there are a few guys using that set up, not sure if the aftermarket hard pipes work as easily.
running the stock mkiii piping and intercooler will equate to running hot air through a crazy straw.
get yourself a small npr intercooler and an ebay intercooler pipe kit.
hey aaron is there any way you could give me the dimensions on your innercooler. i found one on craigs list and was wondering if they were the same size.
oh and those pix make me want to cry comparing them to my engine....
also here is a question.... the person i purchased my car from bypassed the o2 sensor is that going to cause a problem after the turbo install?
well obviously my check engine light is constantly on, and at random times at a higher speed and/or rpm it will kind of sputter but i am not sure if that is because of the o2 sensor or because of one of my injector plugs keeps getting loose. damn the old plastic plugs......
would a 23.5"x10"x2.5" 2" inlet and 2" out intercooler fit up there behind the grill??
Here's my setup, 12x24X3 2.5in/out. Fits with about 1/2" before it would show out of the bottom of the bumper. Right side tow hook removed and a notch cut on the right as well. Hope it helps. Oh and there is no way I could see keeping the stock AC system in place and clearing the IC im using unless your ok with it rubbing or making a modification to the bumper beam to add clearance.
yea appreciate that 2j that actually does help me out alot. thanx for the pix as well....
Glad I can help a little, im just not sure how you would want to go about routing the tubing to the TB, its going to be different from mine with a xM engine.
1 - 19 of 19 Posts
