Has anyone seen or used this fuel injection ECU? This seems to be a serious attempt at a low cost batch fired fuel injection system that can use Speed-Density, Mass Flow, or "Alpha-N (Throttle Position/RPM based).
The cost of this DIY system is US$150-ish. :shock:
These guys are serious. There is a discussion group that is REALLY active.
The 2 fellows doing the designing are part of a larger non-profit group designing EFI/Ignition computers for fun!!!!!
There is tuning software and other support tools available.
Apparently the Alpha-N sensing technique is that used by racing teams when high overlap cams produce poor vacuum.
Their MAP sensor is suitable for using on turbo'd systems.
The system uses an O2 sensor so in idle there is closed loop operation.
Apparently, users have taken these through emissions testing and passed. Although a visual inspection could fail them.
The current version does not control ignition, but a new upcoming "Ultra-MegaSquirt" will combine these features.
Wow. Anyone working on this :?:
