1 - 4 of 4 Posts
Ok so finally i gots me my 6m-ge, and due to the diffrent style crankshaft pulley i have to use the different style belts for the alternator and the water pump. By the way i have a 83 ptype
so since my alternator was messed up i decided to go bigger like a 80 amp 88 mkiii alt, more power to power my system.
So my mechanic called saying that he needed a plug that would fit the MKIII alt.
so i did some searching here in tha forum and found that, I need a plug from a 84/85 supra, to cut out the old plug and put in the new one.
Question: do the color of the wires match the 84/85 plug from my 83,
is the above information the correct one if you can tell me
Discussion Starter · #2 ·
well people my mechanic figured out the wiring my himself and also the plug issue, so that is done,
have you noticed a differance in your alt. i put a 89 alt in my 85 and didnt notice shit. probly cuase it was bad.
yeah i noticed that it charges at like 14 to 14.5 14 at night with lights on and fog lamps, and 14.5 at day sometimes a little higher
1 - 4 of 4 Posts
