1 - 11 of 11 Posts
Unfortunately i have the double v belt. Has anyone figured out a decent solution.I need to upgrade it for the electric fans on 5mgte
Check out the FAQ. 93 Camry works with 84/85 plug soldered in and then read about the charge light fix.
Easy enough to just switch the crank pulley, water pump pulley, and lower alternator bracket to have the later setup.
The round plug can be bough new. $12 from Drift motion I think. And follow the repining pictures in the thread. Then do the charge light mod and you are all set.
Diagram for Repinning
Charge light mod
Round Plug fom Drift Motion, just haven't found anywhere else that sells them.
I forgot to mention the need fo the 84/85 crank pulley but I was able to use the original alt. bracket in my 83 unless my memory is fading.
The early alternators have the two outie ears and the modern alternators have the opposite big inside ear.
Perhaps I used an 84/85 bracket and forgot/
Discussion Starter #10
Im going to do the pulley swap. I know i need the crank pulley the water pump pully and most likely the brackets for the 85 alt. I plan on using the 120 amp mr2 alt and yes the fuse box and wiring has already been upgraded to hold the power. Im ordering the plug for the 120 amp mr2 alt and im away of the charge light fix.is there anything else i need to do the swap? Also does anyone have pictures of there 85-86 setup?
Discussion Starter #11
1 - 11 of 11 Posts
