1 - 10 of 10 Posts
Hi all, I just removed my antenna assembly to change the antenna and the gears and gear box is destroyed. So I’m looking for one if any of you has one for sale, thanks
17008
Dan, if the gear in your fingers has no strip zones, you are ok. The mast itself with the nylon rope is still available I think. The clutch is made to slip a bit everytime the antenna reach top or bottom.
Unfortunately, the plastic part that holds everything together with the sea clip is broken
There are aftermarket antennas you can use if you search around here
1983 Red Mk2 M/T 7MGTE Swap, Bone stock M/T Black Mk2 1984, 1989 Red Mk3 A/T Turbo
I can probably pull mine out from my black car. I believe it works
1 - 10 of 10 Posts
